Thanks. And fwiw, he's not a licensed electrician, though was an assistant for awhile and has been in this business for quite awhile.
Unfortunately, my main breaker box has a lot of unlabeled breakers (they added on a second one, which is well-labeled). I do see a pair of 40 amps (grouped as though they're a 220v), so I presume that's the one that feeds this. No 50's, though.
The hot tub guy noted how much more expensive 50 amp fuses are, so I was hoping to avoid doing that.
Looking that up now, it appears that the huge expense is for a GFI 50 amp. Am I thinking right that if we upped the main box to 50 amp, and ran the hot tub with the 40, it wouldn't be too bad? We could see if the 40 amp tripped a lot, and if so, then up that to 50 amp? Depending on the wire size; if AWG 6, from what I understand. The run from the main box to the GFI is short, about 10-15 feet (if that). Then about 25 to the hot tub.
But if so, would it be safe to go that route?
