Re: New pool proj.Flagstoning around (and on) my fiberglass
Hi! Where are you? I'm waiting for more info on your progress!
I've used silicone and is very easy to set up. I've aplied the silicone to the mat, then put into place, make sure border is dry, you may have to drain water to leave about a foot clean to install the tile. On my case I didn't needed the tape silicone and tile were light enough to hold. If you plan to use white grout, then use white silicone as adhesive, that way any over spilling could be cover by the grout. I started using clear silicone, then when I apply the grout there were a couple overspilling you could see the clear silicone. Also keep in mind the levels of your pool, if you have minor level differences that cant be seen without a waterline, installing the tile would make it visible. I installed mine with pool half full and using top border as guide, and when I filled up there where many parts where the pool had sinked you could tell the difference on the waterline, therefore use current waterlevel as your level. Finally I've silicone Based Grout, fast setting, easy to clean, try not to let get on the water too much, my guess is that it adhere to my cartridge filter.keithw said:I like the tile. How easy/hard was it to put on? Did you have to tape up each section as you put them on or does the adhesive hold them up as soon as you set them? Did you buy it as a kit or just buy tile and silicone separately? Do you use silicone to put the tile up and are you also planning on using that to do the grout work?
I bought my light sockets on Amazon, http://www.amazon.com/Generic-Wedge-Bas ... d_sbs_hg_1
