I have been reading this forum since October and have really learned a lot thanks for the information. I am in the process of have a pool put in well construction will start on Febuary 1st. Pool size is 18X30X46 True "L" IG vinyl pool. I have a few question and would really appreciate any info. I plan on using the BBB method to treat the pool. After reading the thread on the Liquidator I have been convinced that its the way I want to go. I will also be adding salt to the pool somewhere between 1000ppm to 2000ppm. What are the ideal (correct) test results when using the BBB Method and will the salt change what these numbers need to be to keep the pool clean and clear? Again thanks for the info.
