This is what the instructions state....
Chlorine (Free, Combined) Test1. Rinse and fill large comparator tube to desired mark with water to be tested.NOTE: For 1 drop = 0.2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample.2. Add 2 dippers R-0870. Swirl until dissolved. If free chlorine is present, sample will turn pink.NOTE: If pink color disappears, add R-0870 until color turns pink.3. Add R-0871 dropwise, swirling and counting after each drop, until color changes from pink to colorless.4. Multiply drops in Step 3 by drop equivalence (Step 1). Record as parts per million (ppm) free chlorine (FC).5. Add 5 drops R-0003. Swirl to mix. If combined chlorine is present, sample will turn pink.6. Add R-0871 dropwise, swirling and counting after each drop, until color changes from pink to colorless.7. Multiply drops in Step 6 by drop equivalence (Step 1). Record as ppm combined chlorine (CC).
When I tried this I kept adding droppers and could not get the water to change back to clear..... You end up using a ton of r0871 and running out... Are there any other ways of testing cc
