Re: Newbie; will probably need to drain pool soon; suggestio
frogabog said:
Sounds good!
All except the chlorine at 2ppm. At 65ppm CYA you should never be lower than 5ppm, and your high target (end of day dose) is 10ppm.
Time for some bleach?
Frog, the landlord is paying to have a pool cleaner come over every week to take care of the pool. He puts in 3 trichlor tabs/week at no cost to me. What I did last week when I saw the pool was at .5 TC after he put in the tabs was to take a tab and run it along the side of pool, scraping off part of the tab. That pretty much instantly raises my chlorine level. I guess I'll do that every week after he leaves to get the chlorine above 5 and then let it drift back down during the week. If the chlorine level reads too high, he only puts in one or two tabs.
Shane1 said:
Thats good stuff! Since you have a cartridge filter you might have a water spigot plumbed into you system. It would be easier to use that instead of the submersible pump to get water out of the pool.
Great idea; I wish that I had thought about that a bit. I know of one spot that looks like a normal faucet on the filter but I've never used it. I'll have to try that. If I can get the water to flow faster than the 1/2 HP pump that'd be very nice; it can take a long time to water the yard.
There's also the 1 1/2" drain valve but I'd need a fire hose for that.
linen said:
You were right...except that the rising CYA level and the lowering ph level that corresponds to using trichlor, probably makes the bleach cheaper. In a pool of 18000 gallons, a 3 oz trichlor tablet will raise CYA by 0.7 ppm and lower pH by 0.06, which in process lowers TA. As you know, only way to lower CYA is to drain or RO treatment, both expensive and time consuming. Countering the ph drop might be done by aeration (probably not fast enough for constant trichlor usage) but more likely by raising it with more chemicals (borax, soda ash) which also raises TA(each at a different rate, neither which is equal to the TA drop due to the Trichlor) at an additional cost. All this makes for much more complex pool chemistry management than just relying on good ol' Sodium Hypochlorite for a Trouble Free Pool.
Good stuff. Since the tabs are 'free' to me - the homeowner hired a pool cleaner responsible for chemicals - there's no incentive for me to use anything but the tabs that the pool cleaner uses.
Draining the water costs me money but since it's been 105+ here for a while, the landscaping needs water. I simply pump water out of the pool onto the landscape. Since the landscape needs to be watered anyway, the drained pool water doesn't go to waste so again, no additional cost to me.
I've been using tap water for quite a while and the TA seems pretty stable. The TA was originally >300 but I lowered that with almost 3 gallons of muriatic acid. I haven't put in any more muriatic acid but I think that the pool cleaner has added a little bit to keep the TA and PH down.
I plan on continuing this process and hope to get the CYA level down some more, as I won't be needing to water the landscape nearly as much in the winter but the pool cleaner will still be using trichlor tabs.
