I have a question about the Intelliflo VF. I set the pool size to 15000 gallons, the number of turnovers to 1, and the pump run time to 24 hours. I also set feature 3 to run at 40 gpm for 2 hours for skimming (just made up that flow rate... is it adequate?).
By my calculations, the skimming time would turnover 4800 gallons, leaving 10200 gallons to be turned over the other 22 hours. That would mean the pump would flow at around 8 gpm. However, the reading on the pump shows 15gpm when I run it with these settings.
Is 15gpm the minimum flow, or can it just not detect lower flow rates? The pump manual even talks about running at 10gpm when filtering in an example it gives.
