- May 14, 2022
- 10
- Plaster
- Jandy Truclear / Ei
Hello All,
New pool owner here , did my best to find answer before posting, really want to learn and maintain the pool DIY
Just for my Taylor kit a week ago and did few times testing , compare with Leslie and added some chemicals based on recommendations
Of Taylor Chemistry Booklet and Pool Math App.
First 2 weeks pool builder just added Muriatic acid and on day 10 added liquid chlorine.
CYA on Leslie’s test results showed 0
Balanced PH and added chlorine and dry Stabilizer.
Now readings are
PH 7.4
FC 0.2
TA 75
CYA 75
CH 190
Pool Math recommend SLAM and drain some water to lower CYA
Question is CYA 75 that critical to drain some water ? Or better to focus on get stable FC level and /or other numbers ?
Please help
Now readings are
PH 7.4
FC 0.2
TA 75
CYA 75
CH 190
Please help
