Good Evening,
We've been running our pump 24x7 on the low speed pretty much since it got installed at the end of May.
No issues whatsoever. Then tonight, I go to move the pump from low speed to high, as we had a tree trimming company out today to trim back some oaks.
The pool was still clean, but I figured some dust and such probably made its way to the pool, so lets run it on high tonight.
I flipped the switch from low to high and only heard humming. I thought maybe the motor was a bit hot and to give it some time to cool down. Came back in an hour or so, it was cool, so I tried to turn on low again, nothing but the humming noise. Back to high, same thing. Unplugged pump for a bit, came back, still same thing. Then I turned to google and learning about the capacitors that can go out in pumps.
I tried calling Hayward, but they closed at 5pm (I'll call in the morning). What are my next steps here? Anything I should consider before I call them?
Fortunately, I measured my chlorine this morning and it was spot on and I have some liquid on hand that I can use to supplement. Are these capacitors locally sourced? Or am I going to end up waiting on Hayward to address it?
