I have at least three issues in my in ground pool and Jacuzzi.
1. There is a water leak from the pool at the tiles at the waterline when the pool is full. According to a leak detector service, that leak runs around 37 ft.
2. I have air in the strainer housing and in the return jets in the pool and Jacuzzi. In the morning when I check everything out before I turn on the pump the strainer housing next to the pump is empty. There is no water inside.
3. There is backflow from the Jacuzzi each night when the pump is off. The water level goes down about 1/4" a night in the jacuzzi. I did a die test and the water was backflowing from the return jet in the jacuzzi. When the pump is on the jacuzzi is off. Only the main return into the jacuzzi is on and the water is flowing over the waterfall opening into the pool.
We had a leak detector service come out and their report says that the pressure in all the lines are good. They found the 37ft leak in the pool at the tile/waterline. They indicated that the air leaks are from the ball valves on the suction side for the main drain, skimmer, and cleaner. Because of the high cost of all the repairs I decided to get a local pool service tech to look at the plumbing. He replaced the o-ring on one of the J valves as well as the lid on the strainer housing next to the pump that was cracked. This did not stop the air leak. I did the soapy water test on the suction plumbing and found nothing. There is no water under any of the equipment or above ground plumbing.
I decided to fill the pool to the usual level and not add water anymore to see what level the water would stop going down. I turned off the suction line from the skimmer. Every morning I would check the level of the water in the skimmer. Each day it was down around 1/4".
On the 5th or 6th day the skimmer was EMPTY. The water in the skimmer had gone from down about 2.5" to being EMPTY. The water in the pool was below the skimmer opening to the pool. You can hear water gurgling around the skimmer housing.
I believe that there is an underground leak in the skimmer line. That is what is causing the air bubbles as well as the water still leaking below the other leak at the tile line in the pool.
Am I correct?
Here is a link to a youtube vid of the skimmer with sound:
Skimmer & Sound
Am I correct?
Skimmer & Sound
