Was getting the pool ready for swimming and all seemed okay, but yesterday I noticed no bubbles coming from the jets, and the Cell LED was flashing green indicating "Check Cell". I have not checked the chemistry yet, but the water was okay last time I did check (a month ago?)
My IC40 was bought June 29, 2020 - less than two years ago. They have almost doubled in price since then. Very frustrating.
So, I'm hoping by some miracle things aren't as bad as they seem.
I inspected the cell - there was a bit of calcium. I acid washed using 1/4 acid to 3/4 cup water. Cleaned up fine. Same result.
I acid washed again, 1/3 cup acid to 2/3 cup water. No difference.
Checked the panel - says 0ppm salt and water temp 254 degrees. No errors.
I wondered about replacing the thermistor and thought it was part of the flow sensor. But I came across a pic that shows exactly what is attached to the plumbing after the pump and before the filter, and now I'm wondering if *THAT* is the temperature sensor? (Photo is copied from this site and belongs to "Photogrammer" - I hope it's okay to use)
Recommendations?
Thanks.
Recommendations?
Thanks.
