So its normal to feel air?Welcome to TFP.
Modern pumps have fans in the back to cool the motor.
Wow..have had this pool for years and idk why but i never noticed! New pump tho so maybe thats why! Also my psi is around 18…good? 27 ft round
Cartridge filter…new in june…im thinking it was 12 newOld pump probably did not have a cooling fan.
What type of filter?
When was it last cleaned?
What is the filter clean PSI?
Different pumps with different flow will cause different filter PSI.
Old pump was 13 yrs old so prob no fan…thank you! Never thought of thatCartridge filter…new in june…im thinking it was 12 new
We recommend filters be cleaned when pressure rises 25% from clean pressure.Cartridge filter…new in june…im thinking it was 12 new
There was probably a fan.Old pump was 13 yrs old so prob no fan
Will be closing soon so will clean it then. I thought that may be why it was high. Alot of learning with a pool! Thank you!We recommend filters be cleaned when pressure rises 25% from clean pressure.
Your filter should be cleaned.
DE Filter Use and Care - Further Reading
www.troublefreepool.com
I would test is your pool passes a Overnight Chlorine Loss Test and if you have algae clogging your filter. I am sure your water is clear and, yes, algae can be in clear water.
