OK, I’m stumped. My 2004 Whisperflo 2.0hp filter pump motor just started cutting out randomly for less than a second at a time. System is controlled by a Jandy One-Touch RS8. It happens about every 30 seconds to 2 minutes. The motor and capacitor cover are NOT hot at all. I had this pool built in 2004 and nothing has changed. I’m estimating 20k hours on the pump/motor. Pressure runs 18-22 PSI through a Triton Commercial sand filter. Pool and spa has five 1.5†return lines and two pop-up heads near the main drain which assist the in-floor cleaner.
I just backwashed the system a few days ago. Good suction and flow from the returns. No weird sounds. No leaks.
Any ideas?
Motor or Jandy control issue?
Thanks in advance!
Any ideas?
Thanks in advance!
