Thread: AquaChek Salt Test Strips
    ktdave's Avatar
    Katy, TX
    888
    Just want to be sure here (take a look at pic). Do I read this as 5.6 (3890 ppm salt) at the apex of the light color?
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Yes, 5.6 or maybe 5.65.
    ktdave's Avatar
    Katy, TX
    888
    Thanks!
    Pool School
    TF Test Kits
    Aug 2007
    Riverside, CA
    88
    When I tested mine, it landed in the same place. I took a sample to the pool store (not leslies) and they tested it with their Goldline hand held tester thing and it was 2700. Big difference! Not too sure which one to believe.
    ~Debbie~
    28k, 22'x37' freeform 3.5'-9'deep
    w/ 7.5' freeform spa raised 18" above pool, Gunite/dark gray plaster, 3 rivers flagstone,
    Aquarite SWCG, Aqualogic ps8, Frog, Colorlogic LED lights.
    Completed 2/06, in Sunny So Cal!
    Guest
    ask the pool store when was the last time they calibrated the Goldline meter. We use a Goldline meter that we calibrate on a regular basis and the strips also and I KNOW the strips are usually withing 200 ppm of the meter! Also remember that EACH bottle of strips is individually calibrated and you have to use the chart on the bottle the strip came out of to get the ppm reading!
    Aug 2007
    Riverside, CA
    88
    Thanks Waterbear, I think I'll take a sample to another store and see if it's different on their meter. We have several nearby.
    ~Debbie~
