<Update>
I have made some additional changes after daily observations. I noticed inconsistent flow rates with the pH Adjuster which impacted the pH control in the pool in a very small way. My pH has leveled off since I introduced the pH Adjuster as I hoped it would. My pH Adjuster was great at slowing down the climb of my pH level in the pool but I could not get the pH Adjuster to bring down the pH in the pool on its own. I thought there is a connection with the flow thru the system. On the initial install of the pH Adjuster, I used two “Y†connectors as soon in the diagram. I decided there might be some hydraulics issues involved with the “Y†connectors. I removed the “Y†connector on the pressure side and drilled another hole into my pressure PVC line after the filter. This stabilized my inflow to the pH Adjuster tank. I decided to remove the “Y†on the suction side as well and plumbed the pH Adjuster directly to the PVC as soon in the new diagram. I added PVC ball valves between the tanks and the PVC pipes so I can take them off line for servicing. I am waiting the arrival of the flow meters and two flow control valves which I am going to install on the pressure side to regulate the flow when my solar heater comes online.
I will take pictures of the equipment once everything is installed.
