Thread: Test results
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Test results
    Ok, here are the results of our water test from today.
    FC 9.1
    TC 9.1
    CC 0.0
    PH 7.4
    ALK 130
    CY 70
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Those look good. (I am assuming CY is cyanuric acid.)
    Total alkalinity could ideally be a little lower, but it should be fine where it is.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Im sorry CY should be CYA.
    What should my chem level goals I need to achieve and maintain be?
    Les
    Helpful Links:
    You want FC to be 5 or higher at all times. CC should be 0.5 or lower. PH between 7.2 and 7.8 and if practical between 7.4 and 7.6. ALK is probably not crucial, I would aim for 70-90, but there probably isn't any reason to work on changing it unless your PH is drifting up anoyingly. Similarly, for CYA I would aim for 30-50 unless you have a SWG or really high amounts of direct sunlight, but again there is no strong reason to work on changing it. You might want to test your CH and make sure it is 400 or under.
