Has anybody ever made their own? I've got a bunch of cotton gauze I could use (not like medical gauze; it's a closer weave. Think gauze curtains) What do you think? Will it work?
Thanks!
Thanks!
anonapersona said:Here is a source for a 5 pack for $3
http://www.poolproducts4less.com/search.aspx?find=skimmer+sock
anonapersona said:I really like that place for supplies, Polaris parts are reasonable. Last time I ordered from them I got a ton of stuff, something like 10 3 packs of Polaris tail scrubbers and 8 5 packs of skimmer socks, plus a few Polaris parts that I will need eventually.
That's funny, thought I was the only dummy to try that... :lol:Peter_S said:BTW...never try to add DE through the sock...lol...lesson learned
britinusa said:...then just drop a small rock in there to keep it from floating when the pump is off.
britinusa said:dpool: Im not sure what you are referring to when you say trap? But i put mine over the skimmer basket, in the top, then just drop a small rock in there to keep it from floating when the pump is off.
Peter_S said:dpool: the sock has to go in the first skimmer basket...the one inside the pool. The basket with the clear top that is attached to the pump is too inconvenient to change and in most cases has a side entry that isn't suitable to use a sock in.
I assume you also have a basket in the skimmer that is inside the pool??
