Hello TFPers...just posting with a little update. It's been over a month and I'm still loving the LQ.
I had a total of 5 children and 4 adults for four straight days splashing about and enjoying the pool from after breakfast to bedtime snack time recently and I only supplemental dosed a couple times to keep ahead of the 'stuff'. Never a cloudy or dingy (that's DIN GEE, not Ding-E) looking pool. I've backwashed a couple times at most and added water here and there.
I have noticed over the last couple weeks (sauna like conditions) that my FC was dropping quite a bit during the day but not at night and no CCs even when I had the troops here giving the thing a real workout with sunblocks, etc. (Despite increasing the flow on the LQ.) At first I just attributed it to the weather as this is truly the hottest, most humid we've had in my recent memory....
It used to be that if I opened it up fully on I could test 10, 11, 12 on the FC...with 6% Bleach!!! Well she was on almost full flow and I was getting 4s 5s and sometimes 6...hmmm...something not good.
I was getting up in the middle of the night to make sure the darn timer was set to shut off because I was refilling LQ way too often the last couple weeks.
So yesterday I got a 4.5 FC straight from the return, added a gallon of bleach directly to keep at max level for my CYA of 40, refilled LQ AGAIN, check the ONFCL and got no loss overnight, O CCs. LQ at a hair less than fully on. Tested today and have 7 FC..which is good but a totally full LQ on full flow should be a 10 or 11...And let me just say you will blow through 8 gallons of bleach faster than you imagine on full flow. So I got fed up and decided to test CYA...
CYA was down to MAYBE 25 from 40-45. I say maybe 25...it was awfully close to 20. So sun sun Mr Golden Sun has been literally sucking cash out of my pocket for a couple weeks. I know its been at least a month since I checked CYA and my usage pattern shows that splash out is definitely to blame..my deck was constantly soaked during the long weekend party... So the socks are danglin' in front of the return with 2lbs of CYA in them.
So...here's a code for ya...
XY CYA PDQ if FC WHOOSH....
LQ is turned down to its normal 2-3 and we'll see what happens after the CYA gets added.
