i installed this intermatic t101r3 120v timer today, and the manual lever kicks on no problem, but the timer itself does not move/work, i cant see what i did wrong, as the clock motor wires, neutral/hot are pre installed, and are allready mounted w/ eyelets on the terminals, am i missing somthing? i wired my supply line to the #1 pole, and my load to the #2 pole, grounds are together and to the box, and neutrals to the A pole, whats going on? thanks!!
