Results 1 to 7 of 7
Thread: solar cover size, slightly smaller than pool?
    Aug 2009
    Andover MA
    19
    My pool is little larger than 16x32. Shall I choose the solar cover size 16x32?
    Is the solar cover supposed to be floating on the water surface? Or should it be larger to cover the coping?
    Also, how about the stepping area? Just leave it?
    16 ft x 32 ft Rectangle 20k Gal, in ground, gunite plaster
    Hayward EC65 DE filter 68GPM, Hayward super pump 1HP, Merlin robot (similar to Aquabot, can't turn on, anyone can fix it?)
    Chemicals: BBB. Tayler K-2006 test kit. Located in Andover MA.
    Jan 2009
    Cupertino, CA
    1,966
    Re: solar cover size, slightly smaller than pool?
    The cover should float on the water, and ideally reach the walls on all sides but not drape over the coping. If you have some water still exposed it's no big deal, you're just not getting 100% of the possible benefit (which is mostly reduced evaporation).
    Not sure what you mean by 'the stepping area'?
    --paulr
    BBB "Intermediate Swimmer"
    West Michigan
    108
    Buy the cover the same size as the pool. My solar cover pretty much lays flat on the surface of the water with a bit up one side of the edge. Its perfect when its flat, but we don't usually get it perfectly flat. We didn't cut the cover for around the ladder, it's just kind of is there. The idea of the cover for us is to keep leaves out and temp up at night when we aren't swimming. Wrinkles on covers don't bother us...
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    If you are extremely worried you can buy one larger and cut it but if it is just a small gap here or there, it comes with the territory if you have any air pockets when putting it on.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Aug 2009
    Andover MA
    19
    Thank you all. Got my solar cover 16x32, seems a good fit.
    Aug 2009
    Andover MA
    19
    BTW, which side should be up? bubble side or flat side?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Bubbles down.
