Thread: Basic Water Maintenance for Salt Pools
    Have had a salt pool for 4 years but not clear on basic water and chemical maintenance. using AutoPilot Digital with SC36.
    How do I determine what % to run the chorine generation at?
    Do I need to 'Boost' on a regular basis? Or is there any form of weekly maintenance/shocking?
    Seems every time I get water tested I often require to add a lot of stabelizer. Should I just be adding some regular dose of stabelizer to keep levels good?
    Thanks
    5061 Gallons
    Cartridge Filter
    AG Intex 16' x 48" Ultra Frame
    1,500gph (5,678 L/hr.) filter
    Feb 2008
    Denton, TX
    5,062
    Re: Basic Water Maintenance for Salt Pools
    You run your chlorine percentage at whatever level it takes to maintain as close to a constant FC as possible for the FC that you require for your pool. What your FC needs to be is based on the Chlorine CYA Chart for salt pools.
    You only need to shock when needed. The reasons to shock are when your CC is > 0.5 ppm, when you lose more than 1 ppm FC overnight, or your FC drops to zero.
    Only add CYA when the test indicates that you need to add some. Depending on your filter type, you may need to add some from time to time but you would base this on test numbers.
    If you don't have a good test kit, you really need one. My suggestion would be a TF-100. It allows for you to test all of the required parameters for excellent pool maintenance and is a great value. See the link in my sig line.
    Mar 2009
    Huntsville, AL
    156
    Welcome to the forum!
    There is an excellent article on water balancing for pools with salt water generators in the Pool School. Click the link at the top right of the page or click the following link ti go directly to article: http://www.troublefreepool.com/pool-...ater_generator
    Most people here advocate regular (daily or at least several times per week) testing of the pool water using a high end test kit such as the TF-100 or Taylor K-2006. A comparison of the kits can be found in this article under the Pool School: http://www.troublefreepool.com/pool-...kit_comparison
    SWG add chlorine slowly, so it is better to add liquid chlorine (i.e. regular bleach) if you need to boost the chlorine level quickly. The Pool Calculator can help you determine how much chlorine is needed (are any other chemical for that matter). It too can be found under the Pool School, but here is the direct link: http://www.poolcalculator.com/
    Hope that helps a bit. There will be other folks, who are more knowledgeable than I, chiming in shortly!
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by 257WbyMag
    That is, when you lose more than 1ppm FC overnight with the SWG off.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2008
    Texas
    132
    Pool store stabilizer testing is frequently not accurate. You will have better control of your pool if you obtain a pool test kit that uses a view tube to read the amount of stabilizer. Stabilizer levels generally do not change much during the summer unless you backwash frequently or you frequently are adding water due to runoff.
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
