- Jul 15, 2010
- 10
Those sand filters are cool! How much do they run? LOL And what it the yellow thing on the wall there?
HeatherChampaggne said:Those sand filters are cool! How much do they run? LOL And what it the yellow thing on the wall there?
HeatherChampaggne said:alright so if i get this sand filter pump next year ... I can run it with my 1500 GPH pump? Can I also find a heater? (electrical?) If so lead me to it. Now I am gearing up for next year already! LOL
HeatherChampaggne said:oh i am confused now... in that picture didnt you have your intex pump too? ah i hope i can figure this heating situation out before next summer. It gets cold here at night... it be nice to heat it to about 80.... lol
Whats that other little machine ? LOL I thought it was you pump that came with the pool!
rghilliard said:crookm11, that is a nice looking setup you have there. Is that gravel around the pool?
I really want that filter too, but I guess I'll have to hold off for now.
crookm11 said:HeatherChampaggne said:Those sand filters are cool! How much do they run? LOL And what it the yellow thing on the wall there?
The yellow thing on the wall is the magnetic light by Intex. The light works great too. It really lights up the pool at night. I was worried about the sand filter being just another inadequate pump from Intex. Boy was I wrong. This pump is great. I bought the pump off of ebay for $250 delivered. I recommend this pump for any of the larger Intex pools. The hookup is straight forward and had no issues with installation.
Mark
mcoonan said:crookm11 said:HeatherChampaggne said:Those sand filters are cool! How much do they run? LOL And what it the yellow thing on the wall there?
Mark
The Intex Lights are on clearance at Walmart. (that is if you can find them in a store near you) for 35.00. Just an FYI!!
bill022572 said:HI - some questions for all of you Intex owners. I have a 15' x 48" round metal-frame Intex pool with a 1500 gph pump. I just bought an Intex model 8110 saltwater system (this is just the chlorine generator only) so I will be using my old pump. My questions are : What is everyones' opinion on these systems ? If I now have chlorine in the pool (it has been up for about 4 months) : should I let the chlorine level drop before adding the salt and installing this unit ? And : basically any other advice or opinions or etc. about installing and using this system. Thanks - - - - BILL
crookm11 said:Good morning TFP!!!
I would like to share my latest project with everyone. Added a thru-wall skimmer and upgraded the plumbing for the main drain and skimmer so they can work together. I used 2" pipe and reduced to 1.25" pipe for the main drain and skimmer. Please follow the pictures below.
Enjoy.
1. pic of parts used for project.
2. Waterway Flo-Pro II Standard Mouth Long Throat Skimmer #560-D0A60S and pic of Intex drain valve.
3. 2" fitting added to the Sand Filter Pump.
4. Fittings put together for Skimmer and Drain.
5. All fittings and ball joints together and test fitted on pump.
6. Pics of plumbing finished on pool. (Ball joints are used to control the suction from the skimmer and drain).
The thru-wall skimmer works AWSOME!!! The liner holds the skimmer just fine. I'm in the process of putting in a bigger Intex pool this year. 24' x 52" Ultra Frame. I will be adding the thru-wall skimmer to the new pool and will post the process of mounting it.MrsFusion said:Mark, how did the thru the wall skimmer work for you?
