I put in a Dual Speed 1.5 horse Super Pump at the beginning of last winter and could not have been happier. I do not close the pool for the winter and running the pool at low speed was plenty to keep everything from freezing while saving me a few dollars in electricity.
The pump has a switch on the back that you have to manually flip to take the pump from low speed to high speed. Also the manual stated that you should not change the speed with the pump energized.
Does anyone know of a timer that would work with the Hayward that would:
a. Turn the pump on/off on a schedule
b. Flip the speed from low to high on a schedule
c. all of the above
I know I can do a with a water heater timer, but I would like to find something that would do item C...
Anyone know of a source for complex timers for pumps (well it's not a really complex function, but more complex than a plain water heater timer)?
c. all of the above
