Thread: Rain
    Mar 2010
    Spring, TX
    1,082
    Rain
    What levels does rain affect? If I remember correctly, rain will lower pH levels.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Rain
    Rain might either raise or lower the PH, though raise is quite a bit more common.
    Mar 2010
    Spring, TX
    1,082
    Re: Rain
    So it works kinda of like the returns do when pointed towards the surface?
    Re: Rain
    Yes, rain aerates the water, which tends to cause the PH to rise. Rain is also just slightly acidic. Unless your TA level is fairly high or there is a lot of rain, there won't be too much change in the PH.
    Re: Rain
    If you get enough rain to make the pool overflow somewhat, you are replacing pool water with water that will dilute all values (TA, CH, CYA, FC).
    Over a normal wet winter here I will typically see CYA decline rather a lot, like 15 or 20 points. TA can be kept up with just a small amount of tap water since my tap water has TA of like 340-ish.
    Also, rain will typically add organics to the pool with a bit of dirt and leaves from my badly sloped flower beds nearby and the leaves and stuff that blows in. So that uses up FC also.
