Anyone have an older Dreammaker spa? My daughter just got a used Dreammaker and is having problems with leaking (BAD) and just discovered that the filter may be missing a part? We looked on Dreammakers site and there is a 2" Filter Adapter? Does that screw into the spa itself to allow the filter to screw into the adapter? Would this cause a major leak? Since the adapter has O Rings I'm assuming that it would create a seal and without it, it may be the root cause for the leak. ANY help you can provide would be greatly appreciated. Unfortunately the manual is less than clear. If you have an older Dreammaker and have any suggestions or pictures on what we should be seeing in the filter cavity that would be awesome.
Thanks so much!
Thanks so much!
