Thinking of getting this pump, 230v, it needs an inline switch at the motor to control the speed. Any reason I can't use it with my existing Intermatic mechanical timer, just wire it in one of legs? I only want to use the timer to turn on the low speed, when I need the high speed I can turn it on manually, so do I still need the additional T206 timer along with my mechanical?
I decided not go digital VS, dual will be fine for me, thinking not as much to go wrong.
basic inline toggle switch
pics below(screen shots, not me) show the 2 legs and ground coming from the load center, the black leg is connected to the black on the toggle switch after it enters the motor(I don't know if this is coming from a timer circuit but why would it make a difference). The power only goes to the switch through the black leg as the timer settings allows, then it could be manually switched to change speeds.
