So new pool owner. I’ve got Jandy equipment. The pump is a VS Flopro ( I believe, I’m not home) 1.65. It’s set to run right now at 1750rpm. My question is every time it turns on it runs through its “priming” cycle for 3 min or so then slows down and runs normally, the pump basket is always full of water when this happens. Is this correct operation? Couldn’t find it in the manual.
Also my Jandy sand filter pressure gauge always reads zero. The water flow is fine, you can see it flowing in the pump, SWG and returns jets are fine. Could it be a bad gauge? The manual says it’s a “self-bleeding” filter, no air bleed.
Thanks!
Thanks!
