- Jul 18, 2020
- 24
- Plaster
- Hayward Aqua Rite (T-3)
Hi there,
I'm currently upgrading my (single speed) 1.5" pool pump to to a new 2" inch (variable speed), and all my current plumbing and pipes are 2", except the connection from the current pump to the remaining system. So my current pump goes via 1.5" pipe to the 2" of my high volume filter, and sucks water in from a 1.5" elbow (suboptimal already) and 1.5" ball valve that connects to 2" piping.
Because I want to have it all properly 2", I've planned to replace all those 1.5" elbows and piping with 2" flex (soft bend, because >3ft to both sides) PVC hose .. (different one than you have in the US.. way more rigid and pressure resistant here in Thailand). I'm going with the flex to get rid of the vibration noise in my house I've had in the past, since the pump is sitting on my basement concrete (no worries about leakage, it would drain out there, since I'm on a hillside).
I've just received the fittings I've ordered and noticed (and not thought about before), that while the threaded side is 2" inside, it narrows down to 1.73" on the side where the 2" hose slips on.. but that "narrow" part is just 2" long.
While it seems to be not ideal, is that something I should be concerned about? Would that actually cause a problem in the flow I should worry about? I have 4 of those fittings to connect the pump on both sides.
I would need to find a 2" fitting with a 2.5" slip on instead, and order a new 2.5" hose - which I couldn't find so far. Seems they only make those in 2-3-4... so I would need to use a 2" threaded fitting, go to 3" and connect a 3" hose and go back down to 2" on the other side.
PS: I tend to overthink/overengineer things.. so.. maybe same situation here
Thanks
Thanks
