2 out of 7 jets aren’t working? Also, weird bugs!
TexasPool128
80
N. Texas
My pool is a couple months old. 2 of the 7 jets are shooting any water. Any reason why that’d be normal?
Also, I have these weird little bugs in my grotto. What are they and how should I kill them? Thanks!image.jpg
jblizzle
43,238
Where are the "non-functioning" jets located?
Are you sure they are not on a different valve setting for a cleaner?
TexasPool128
80
N. Texas
I don’t have a vacuum type cleaner. I swapped that for a robot when planning the build. 1 jet is near a skimmer and 1 is about 7 feet away from another skimmer, opposite side of the pool.
jblizzle
43,238
Well, even if you do not have a vacuum type cleaner that does not mean the pool is not plumbed for one ;)
Is there a suction valve or return valve that is closed that could be attached to one of the holes?
Is the hole directly below the skimmer? Could be an equalizer line and just plumbed up to the 2nd hole in the bottom of the skimmer.
Wait your pool was finished 2.5 months ago? why not ask the builder what they did.
TexasPool128
80
N. Texas
It was not plumbed for vacuum and there are zero valves closed. I’ll ask the builder today. Any idea on the bugs? Thanks!
