Hi All,
Recently upgraded from a 1HP Super pump to a PL2607 1.4HP Pureline Prime 2 speed with the 2Green digital controller.
I have an older H series H200 milivolt heater, with headman switch on the intermatic timer that we used for the SP. I've wired the new pump to the timer, and have just been running without any pins in it.
I'm wondering about the best way to go about running my heater come May/June. Does anyone have experience with the 2Green controllers? I'm assuming that I must run at high speed at anytime using the heater for optimal heat transfer.
My current plan is this when we want the heater in use :
Any other ideas on how to approach this would be appreciated, I'm not really in the market to replace our NG heater as it seems to work pretty well, and we can still find parts for it.
- Set timer on old intermatic for desired time frame.
- Set timer on new 2 Green controller for run 24hours on high speed.
- Set thermostat on Heater to desired temp.
- If intermatic timer is ON but pump timer is OFF --> could heater stay ON with no flow? i dont know if this model has a flow pressure switch or no?
- Will the 2 Green kick back to ON automatically without throwing a 'fault' when Intermatic turns back to ON?
