Our pool has an auto cover that we keep closed when the pool is not in use. We have an auto chlorinator loaded with Trichlor tabs. Last summer, CYA was nearly nonexistent. The water would continually turn cloudy on me, as I could never keep the Chlorine level up high enough even with the chlorinator wide open. I even added separate stabilizer to try to boost the CYA!!
Last month, we opened the pool as usual. Shocked it, etc. now we have the same issue. CYA nearly nonexistent, can’t keep Chlorine level up, pool goes cloudy.
The only shock I could find today was dichlor.
Q1: Is there any problem adding this dichlor shock with trichlor tabs in the chlorinator??
Q2: Why does the cloudy issue keep coming back. We never had that problem before.
