I put muriatic acid in my spa for the 1st time today, after receiving guidance here. It wasnt as bad as I thought. You should have seen me tho, I looked like the mad scientist testing and measuring with my gloves, and goggles and wet wipes just in case....
PH was at 8+, maybe 9 (pretty pink); TA = 175; CYA 32
I didnt want to pour the acid from the bottle and there was so little needed, I used a turkey baster to get it out of the bottle and put it in the measuring cup.
I hope I did it right.
1) I left the jets on but then remembered having the return flowing was good enough. So I turned the jets off.
2) I also needed FC but didnt want to add another chemical at the same time
3) I waited 1/2 hour and tested again.
4) I then added the chemicals for the FC
Everything added was based on what Pool Math said to add.
The new result was PH = 7.6 and TA =125
So still some work to do but going in the right direction. Should I expect it to go down more overnight?
