You have a beautiful pool, and your levels look fairly good also!
With a SWG, I suggest raising your CYA level to around 70 to 80. That should allow you to lower the percentage on the SWG, which will increase the cell life, and should also reduce the amount of PH drift. If the PH is constantly rising, you can let TA fall down to 60 or 70.
