We purchased a house with a pool in IL winter of 2022 so no chance for an inspection. Opened it up in spring of 2023 and it appeared well kept and in working order. It has concrete floors and fiberglass walls built around 1974. Previous owners lived here for over 50yrs. Over the first summer we noticed the “decorative waterline boarder liner” was starting to peel. I emailed the previous owner and mentioned it and asked what the vertical tape was within the pool. She said nothing about the tape. Said they never had a full pool liner it’s always been concrete and fiberglass and that there was extra liner for the waterline left in the garage for us. We closed up the pool in Sept. Spring of this year, 2024 we opened the pool to find more of the “decorative liner” falling off. This time it was bringing what looks like concrete or plaster and paint with it. As the pool starts to reveal itself we are seeing buckling walls. I have talked to 3 pool contractors all with different opinions and all saying the other is wrong!!! So what do I do? What have others done with their hybrid pools and did it work? OPTION 1: remove fiberglass walls and poor new concrete walls within the pool. $50,000 basically rebuilding a new pool.
OPTION 2: Put a plunge pool by Imperial Pools inside of the existing pool. Fill in the deep end make it one level. (pool guy one said run if anyone says they will put a pool inside my pool it won’t work and will fail). $20,000 to drop a pool within the pool.
OPTION 3: put in a liner. Not sure the cost that pool guy hasn’t been over in person yet. My concern here is if the sides are already failing what happens to the liner? Would they also rebuild the sides do you think? Not sure the cost of this one yet. (pool guy one again said he wouldn’t do this option because of the risks getting a liner to fit on the current pool sides that are wavy and not as easy as just dropping in a liner).
