I see that. I had not seen it before posting that last response. We must have posted at the same time. Thanks
Basically although I would still use 2 1/2" on the pad. It makes it difficult to use 3" on the pad and like I said before, the benefit is less that when used for long runs.Would that drawing still basically apply if you substituted one 3" where the two 2 1/2" runs are? Still going both in and around filter and heater?
That only works if you have a float in the skimmer and it seals perfectly which they never do so most setups like that still suck air.He also said if the water line fell below the skimmer it would save the pump from sucking air.
