- May 3, 2007
- 16,886
- Plaster
- Hayward Aqua Rite (T-15)
Then ask him the SPA will be VGBA compliant. With 8 jets, you will want at least 15 GPM per jet which is 120 GPM. VGBA requires suction flow rates to be below 6 ft/sec which requires 3" pipe. You could also go with 2 loops (4 jets each) of 2.5" pipe as well and still be compliant but then you would need to double the drains.I think he thought I was crazy asking for 3" for the spa.
But the main reason for the larger pipe is to keep head loss at a minimum so all the head loss is in the jets where you want it.
