ok here are the pics. The green pipes aree the supply and return to our outdoor woodstove so when its clean it can heat the pool. I can't pump well right now as the water level is low after trying to vacuum to waste. As you can compare it is much "swampier" than the prior pics and the stuff you see floating is all I keep getting up when i scoop.
