Results 1 to 8 of 8
Thread: how many of you are running the Aussie SWG'S?????
    Aug 2009
    SW Wisconsin
    524
    Just curious as to who on here is running units that are built in Australia, and therefore having to use higher ppm salt levels? I haven't started my SWCG up yet, because the water is still too cold for it, but I will have to add the salt soon, and it calls for at least 5000ppm....does anyone else on here use one that uses this much salt??
    Thanks
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Vero Beach, FL
    462
    Re: how many of you are running the Aussie SWG'S?????
    I've got the Aussie built CompuPool CPSC and it calls for 3500.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Jul 2007
    Brisbane, Australia
    874
    whole of Australia runs on 5500 ppm
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by Strannik
    ...and Fosters
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Compupool CPSC 24. 3500 PPM
    Houston, Texas
    8,000 Gal
    IG, Plaster
    Nautilus FNS-48 DE Filter
    Compupool CPSC 24 SWG
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    Quote Originally Posted by svenpup
    ...and Fosters
    No respectable Aussie drink's Fosters. Its the "Old Milwaukee" of Australia, yet marketed/exported to Americans as high-brow.
    Aug 2009
    SW Wisconsin
    524
    I actually like West End and Soutwark better.......yeah my dad travels to Australia's south side and also new zealand for the railroad. those are the two he has sent back here.
    You can hardly find Foster's over there. It's strictly import.
    I'm using CompuPool at 3500 ppm.
    Works great!
    [attachment=0:1yeeva8e]CPSC.gif[/attachment:1yeeva8e]
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
