- Feb 5, 2025
- 97
- Vinyl
- CircuPool RJ-45
Sorry for being slowYup. CYA probably won't dissolve quickly without good circulation but get 30 ppm in there and if it takes 3 days to mush up, so be it.
How to add large batches of CYA
Hey Folks !!! With a large pool, I need 4lbs of CYA to only raise it 15, and I don't think I have that many socks without holes in them. So I use a Tshirt. Plus, I like that it's doubled up for redundancy. *** It can also be scaled down with socks. So I measure out my dose and...www.troublefreepool.com
Count it as added once it's soaking and never sniff min FC for 30 CYA. Everyday FC will drop and you'll quickly get an idea how much you should dose to achieve the never sniff minimum mission before your next test. Min FC is lava.
Got the pool math app and took a look at the test kits, guess ill have to get some additional testing items when I switch over to the SWCG. Reading the pool school stuff if I understand right during my current situation with no filter and limited circulation with a submersible pump should I just keep SLAM levels for the time being?
