I am in the process of installing an 18’ foot Intex. Spent two days leveling so far. Have a 6” high spot so lots of digging.
I plan to use 1” rigid foam. I wanted to get your view on how level the ground has to be if using foam.
For example I assume some small divits won’t matter. Also thinking the foam will be a little more forgiving.
as for the post I plan to use pavers they are flush with the foam.
Would 1” pavers be too thin if so then will use 2” and dig down an inch I guess to make even.
