I've never done it with a pool, but my advice is to put the entire hose into the pool and make sure it is completely filled up, and one end weighted so it is at least below where you want to drain the pool to (but no lower). Then with your thumb firmly over the other end (or a hose fitting with the spigot closed) remove that end and quickly get it somewhere lower than the other end.
