I've been working on bringing a 1995 Watkins Hot Spring Grandee back to life for the last several weeks. I've worked through a number of problems and had a number of setbacks but I'm getting close to having an operational hot tub. I just filled it a couple of days ago and had a number of problems getting it going. I kept getting the blinking light as soon as I powered it up which was really confusing me because the water in the tub was quite cold and air temp was near freezing and the circulation pump was working. Tech support at Watkins told me the reason was that the high temp cutoff sensor in those tubs also have an undocumented low temp cutoff of 10C (50 F). I left a space heater running in the pump compartment overnight and that seemed to do the trick getting that sensor temp up above the low temp cutoff threshold. The system powered up without the high temp cutoff sensor tripping and finally the tub became fully operational.
After getting past that obstacle I was glad to see that the heater was working and the tub seemed to be working okay. It hadn't quite got up to temp by the time I went to bed on Saturday night so I went out to check its progress first thing Sunday morning. The red indicator light was blinking indicating that the high temp sensor tripped and the thermometer I had floating in the tub was maxed out indicating a temp >130F ! Yikes!!
I'm now waiting for the water to cool down enough so I can see if the tub will not go as hot if I set the temp dial to say 1 vs 5 where I had it set when it overheated. My guess is that it won't matter what number I set it at and it will overheat no matter what. There's no way it should have gone north of 130F with the dial set at 5 if the system was working. I'm thinking it might be the heater relay sticking or possibly the thermostat is faulty. The high level shutoff sensor did its job so I kind of think it's okay unless it's supposed to shut the system off way before 130 F.
Can someone help me troubleshoot this and figure out what's gone wrong with this tub?
Thanks
Thanks
