Hi,
I have been fighting green algae every year with variuos level of success. Swimming season is slowly starting here in Australia and I'm losing the battles already...
I have an old 65000L concrete pool. It is covered with a floating blue (bubble wrap type) cover, practially all the time (water still too cold to swim). I vacummed and cleaned it after winter a few weeks ago. Of course it turned nasty after I stirred it but I managed to clean it in a week or so. Each time I uncover it on weekend, the water is nice but there is algae on the walls and the bottom. Sometimes not really visible until I brush.
For the last week I had really high chlorine levels to shock it. 15-20ppm all the time, never dropped. The pump has been running for 8h a day. CYA is really low at the moment (10-20 max) to make the chlorine as active as possible and PH was stable and under control (7.5 this morning). When uncoverer today I thought I finally eradicated the green little monsters. However when brushed I can see green clouds after each bruch stroke again.
Not sure what to do next. Keep the high chlorine going for another week?
Maybe this is normal when there is no automated cleaner preventing algae from attaching to the walls and the bottom?
PH 7.5
CYA low: 10-15
chlorine: 20
PH 7.5
CYA low: 10-15
chlorine: 20
