Hello, this is my first post to the forum. I have a 13,000 gallon vinyl liner salt water pool built in 2014. The cholorinator is the Pentair Intellichlor IC15. We live in mid South Carolina and the pool gets the sun all day long, very little shade. So I'm used to having to run the system longer and at higher %s. This summer I've been running it at 14hrs and 100% to keep FC at 3-4 and sometimes higher when we expect higher bathing loads. Two of my neighbors talked about how their systems couldn't keep up with the heat and have had some algae problems. I haven't had any problems with the water at all running my system this way. A couple weeks ago I dropped the chlorinator to 80% when we had a lot of cloudy days and more rain. FC was at 2. I bumped it up last week back to 100%/14hrs when the heat/sun went back up. However, the FC hasn't budged. I checked the cell yesterday and there was no buildup. I ran the system overnight and tested again this morning both at returns and away, and FC is still at or slightly under 2. I would have expected it to increase especially running overnight. Do you think my cell is starting to die? 4 years old.
Water readings using Taylor K2006 & Aquachek salt test strips:
Alkalinity 90
PH 7.4
Salt 3500
CYA 60-70
FC 2.0
CC 0
If you think the cell is dying, would you recommend me upgrading the SWG to the IC20 to keep up with our hot summers?
Thanks
Alkalinity 90
PH 7.4
Salt 3500
CYA 60-70
FC 2.0
CC 0
Thanks
