Hello All,
We bought the house in October of last year so this is the first summer that I am actually taking care of the pool and I have already spent around $1000 to maintain the pool and try and fix a black algae problem. My wife is going to kill me if I dont get this fixed cause we are throwing way too much money into this pool just to have an available chlorine reading.
I know that you are not supposed to use a wire brush on Pebble Tec but I am at my whits end, so I broke down and got one. I have used the Leslie's black algae killer and I don't think that it is helping. I know that there was previously black algae in the pool when we bought the house only because I noticed the bottle of Black Algae killer on the side of the house. And I can see where the previous owner went to town with a wire brush ans scrubbed all of the pebbles out of some places down to the cement.
Last night I threw 5 pounds of Chlore Brite granular chlorine in the pool before going to bed. That is 4x more that the maintenance dose I use per week. When I woke up this morning and tested the water I had Zero chlorine in the pool. I have two pool chlorine floats (one in the pool & one in the spa). The pool float is loaded up with 4 3' tabs and opened up fully, and the spa float has 2 3' tabs. With all of this chlorine I should get a reading but it is ALWAYS ZERO!!! I know that it is not phosphates or nitrites because I got the water tested and I did a partial empty and fill. I am at the point where I am thinking of renting a sub pump from home depot, draining the pool, pressure washing the black algae wall with liquid chlorine and then refilling the pool with new water. Would this be advisable??? All that I want is to have the black algae gone and be able to have a chlorine level in my pool at all time instead of zero chlorine all the time.
I know that you are going to say you need a water test and I will get the water tested today and post the results tomorrow, the one thing that I can tell you is that after putting in all of that granular chlorine last night it dropped the PH below the lowest acceptable level. Any help, thoughts, ideas, anything please!!! Will draining, pressure washing with chlorine then refilling with new water help???
