We will be ordering our composite wall in-ground vinyl pool this week and are seeking advice. I've been researching the forum for a few weeks and have tried to incorporate all of the valuable information you have so graciously shared.
The pool will be a simple rectangular 20'x40' with a gradual slope from 3.5' to 6', 8' plastic steps and a 6' plastic swim out seat. I've struggle the most with depth (or maybe the liner color ) but after reading many, many posts I think we've settled on this depth. We will not be using the pool for diving but the kids like to search for diving toys in the deeper end and we'll add a slide next summer. The composite walls only come in 42" otherwise I would have preferred 48" walls for increased water depth in the shallow end.
I've attached a picture of the plumbing design in hopes of gathering your feedback. The plan includes 2" pipe for both returns and skimmers, Hayward 1.5hp Super Pump VS, Hayward 30" sand filter and Aquarite 40K SWG. We will also use Jandy Neverlube valves where noted, but are the in the right places or would you recommend more/less?
Is there anything we should do now to prepare for a future gas heater?
I've read conflicting information about the return designs -- should it be close looped or each return plumbed separately? The current design is somewhere in the middle but I'm not confident that's correct.
We will be plumbing a return for the future slide. Since a robotic cleaner isn't on the menu for now, should we plumb a dedicated suction port for a vacuum?
Do I have enough/too many returns and skimmers? Are they in the best places?
Thank you for taking the time to respond! We are located in Vermont and need to get moving on this project if we plan to complete it before summer is over!
