Hey all, been trying to bump my slightly low pH up for awhile to no avail.
my TA is 40
pH is 7.2
Chlorine is ok-spa according to the dip stick, but the levels that baffle me are my Bromine levels are normal to high? Even though they were low months ago....I also dont use Bromine, just Chlorine pucks.
1. Should I bump my TA up with sodium bisulhpite then my pH?
2. Should my Chlorine pucks be in my skimmer basket or a floating container?
3. Can I pour powdered pH+ or Alk+ directly into my skimmer with the pump running?
4. Where is the Bromine coming from?
Also my hardness is non existen, should I add calcium to bump that up?
my TA is 40
pH is 7.2
