Thank you for your reply... I am not sure about status of transfer of ownership... I did check Yelp, Angie's List, CSLB and Better Business Bureau, all clean/positive. I thought the 58 years and being an expert witness meant I had chosen well. However I do not know specific details about why the person I spoke to yesterday was so negative and emotional about the owner of teh company
Yes, I will post on NextDoor -- I searched on there to see what builders people have used but wondered if it was legit...
I hate to lose $3300... ... I will cut the Ozone which saves $2400, and use that to go mini-pebble upgrade, and it was recommended I go with Pentair, so I could ask for Pentair instead of Jandy and hope that is not so much more. I am using shotcrete which is important where I live... I do realize now the schedule of payments is not good - other people I talked to didn't ask for a big sum until excavation, but I will have paid about $13k by then.
Yes I was worried about that - I hope that doesn't make it much more expensive, but yes for sure I want a pool because I want to cool off. I will ask ... if I stick with this builder... I do plan to cut the ozone and just go with the regular chemical system. One of the pool maintenance people I talked to recommended ionization -- he said that can be added later if I wanted to...
thanks, I will get an estimate on that -- the way the pool is now the spa is raised which gives a nice water feature, which would nix the cover -- the spa would need to be set in instead...
I had a price of about $12 k for a cover for a pool 12x28... does that sound right to you?
Here is my contract:
If I stay with this builder, I will cut the Ozone system and go with mini-pebble, and ask how much more for Pentair equipment, and to go six feet deep. I forgot to factor in the height of my children (teenagers) who are over 6 feet tall so a 5 foot pool is not really great for them. I planned to not do decking and thus save the demolition of my flagstone patio - just refurbish that. I do have to do something with at least one side of my fence, the one on the hillside, although replacing the chain link entirely would be great - I got an estimate of $2800 to do that with redwood placed horizontally...
1. DESCRIPTION OF PROJECT: ACI will furnish all labor, equipment, materials, sales taxes, hoisting, transportation, supervisions, coordination, communication, and storage to complete in a good and workmanlike manner the following project: (According to and including the following approximate measurements
NEW POOL & SPA
Pool: Width 15; Max. Length 26’ Max., Area 390 S/F, Perimeter 82 L/F, 3 1/2’ to 5’, three returns
With adjustable flow heads, one skimmer, two main drains, one incandescent light in pool with
new safety cord to be switched at equipment $19,500
Shotcrete instead of gunite, stronger material highly recommended on hillside & high
expansive soil, due to higher strength value $ 2,647
DESCRIPTION SPA
Spa: 7’ by 7’ square. Elevation 18” above pool, located in the shallow end of pool. 8 Turbo
Jets. Face of spa to be tile. Outside rear that is not over pool to be stucco, spillway cascading
water into pool that is 18” wide. Tile, coping and grey plaster to match pool, install
standard white light fixture with new safety cord in spa, light is switched at the
equipment $ 7,795
Tractor access: 4’ wide $ 5,000
DEMO
Demo & remove 352 S/F of existing Flagstone decking $ 1,232
DEBRIS HAULING
Includes loading, hauling & L.A. City and/or county land fill fees, (Clean fill dirt). Ten 10
yard containers $ 6,750
PLASTER
Pool & Spa Finish:
Plaster includes (three) coats of plaster and “eye ball" directional flow heads and main
drain safety covers: FRENCH GREY $ 3,252MASONRY
Coping: Bellecrete Pre-cast, 14” wide around pool 82 L/F $ 4,992
Tile: 6” waterline tile in pool to include skimmer throat, spa spillway, spa dam wall. Tile
Selection (class 1, 2, 3) or an additional charge will apply. Total 140 L/F of 6" tile $ 3,080
GAS
1 ½” poly pipe from existing meter to equipment location to include emergency shut off
valves & unions at meter & equipment location, run to be 40 underground $ 1,270
ELECTRICAL
Electrical from existing service panel to equipment location, 43 L/F total, runs
underground $ 774
Wiring of motors, lights, heater & GFCI $ 1,100
DECKING
Pavers, approx. 650 S/F of Angelus Castle Cobble 1 (Three stone package). Pavers will be
set on a compacted sand base $ 9,100
EQUIPMENT/INSTALLATION
Poured in place equipment slab: This means that we pour a cement slab 3’ x 7’ for
equipment to be placed on, instead of purchasing pre-formed slabs that have a
tendency to settle at different rates, causing stress to be placed on the plumbing
Pre-formed slabs also allow grass and other weeds to grow in-between slabs. $ 650
Filter pump: Jandy E Pump Variable speed, with controller, 2.7 Total horse power $ 1,792
Booster pump: Jandy E Pump Variable speed, 2.7 Total horse power. Increases the
pressure & flow of water going to the jets. Allows the amount of pressure to vary due
to the fact the pump is a variable speed $ 2,992
Filter: Jandy 580 C.L. cartridge filter $ 1,315
Heater: Jandy JXI Pool heater 400 natural gas $ 2,723
Ozone Generator by Del Ozone (Eclipse 4) $ 1,773
Total, does not include permits or engineering $77,737
Please look over it and tell me what you think.
