Hello all,
I've been spending quite a bit of time reading the forums here and am truly amazed at how much information there is. I am the proud owner of a new home and pool that I had built from a dirt lot. The pool had a very difficult start-up and was cloudy after the initial fill in January for well over 2 weeks. Shasta was my pool builder and had various guys come by and dump this and that in the pool and EVENTUALLY they were able to get the thing clear so that I would sign off on the paperwork. During this whole time I was executing the start-up procedure to the best of my ability..... brushing the pool every day and running the pump 24/7. Given that I couldn't see the bottom through the most critical part of the startup, the ended up being quite a bit of buildup on the bottom that attracted all of the dirt that invariably got blown into the pool due to new home construction around me as well as my own yard landscaping being put in. Fast forward 6 months till now. I was on the "pool store" support path for the first few months... buying and adding what they said I needed to keep the numbers balanced, but really did nothing aside from adding acid from time to time and keeping chlorine tabs in the hopper. Just a few days ago I noticed a black mark near the deep end of the pool. I pretty much knew what I was in for since I had been running low levels of chlorine for quite some time. It continued to bloom. Last night I tested at 7.4 ph, .8 FCL, and 1.7 TCL and proceeded to dump (8) 121oz bottles of 8.25% bleach into the pool in a bid to get up to a FCL of somewhere in the range of 30. I neglected to test my CYA levels, but I know they are NOT high... so hopefully the shock is successful. BTW, I have a LaMotte ColorQ Pro 11 tester.
Back to the real reason for my post... I have what I would assume to be buildup from when the plaster was settling on the bottom of my pool. I read a thread here about Ascorbic acid/Citric acid as being a possible solution to get the bottom of my pool clean. I had a guy out fixing a leak in the pool equipment and he had just a handful of grains of "Jacks Magic" "step 2 copper and scale stuff" remover. We tested what little he had in a small area and it seemed to pull the dirt up and clean quite well. My real issue is that I'm not sure 1) if this stuff is the right stuff for my situation (calcium + dirt as opposed to metal stains), and 2) how I fit a cleaning cycle in to my current attack on the green monster in my pool. If you made it this far, THANK YOU. I appreciate you folks and hope that over time I can become a contributor as I learn from my mistakes that I have and invariably will make as I transition to a BBB method for keeping my pool clean.
