Results 1 to 9 of 9
Thread: Skimmer door keeps getting stuck
    I have Hayward SP-1084 Skimmer and the door get stuck up and some get stuck down also. It feels like there is a lot of play in the door hinge has anyone had this or fixed this. Any input would be great.
    Thx Mike
    gunnite bottom and fiberglass walls that have been coated with epoxy paint. Approx. 24000 gallons, sand filter.
    Any One...
    A quick, and far from perfect, fix is to trim the edges of the door so they no longer bind. This isn't ideal as it allows more water through along the sides, but the effect is usually minor.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Mike,
    I may be out in left field here but I had a similar problem as to what you are explaining. I thought I had checked everything and come to find out that I had a small pebble lodged down in the corner. Once that was removed, it worked just fine. If it is a clearance issue, I believe Jason has already explained what to do. Good luck.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Mar 2007
    Collierville, TN (near Memphis)
    94
    I had the same problem in one skimmer and not the other. I decided to switch the doors and it worked. No more problems
    Richardson, TX
    287
    same problem here, I got a smaller door for the skimmer, works pretty good so far *crosses fingers*
    -Thomas
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Can you replace the door? I could not find it on the parts list. Thank you
    it is called a weir maybe that is why you couldnt find it, but you can get universal ones at most pool stores. Walmart doesn't sell these so unfortunately you can't support corporate america on this purchase.
    krcossin's Avatar
    Detroit Burbs
    113
    I have the Skimline Deluxe through the wall skimmer and the lid is real hard to release if you snap it in place, so I have just stopped "locking" it in, just kind of lay it on top.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
