Pedestal Size
Do you want to highlight the bowl or the pedestal? If it is the bowl I would have the pedestal as small as it can be. Just so the pedestal is just big enough for the bowl's bottom to sit on. If it is equal parts bowl and pedestal then have the pedestal as big as it can be making sure the lip of the bowl will clear the pedestal so the water does not hit the pedestal.
I know these are not "real" numbers but without know the size of the bowl......but I hope it gives you something to work from. Share the bowls (pic and size) and we can work from there.
Kim:kim:
